APR Downpipe Review
Old May 10, 2007 | 08:15 PM
  #21
Audinam's Avatar
SoCal Crew Member
Default RE: APR Downpipe Review
so that's normal for stage II? i tried it again today on 5th gear, it didn't happen.
Old May 10, 2007 | 10:36 PM
  #22
Chef's Avatar
Maybe it's an APR problem???
Old May 10, 2007 | 10:46 PM
  #23
swau's Avatar
I get fuel cut too almost every time I use tip to go over 80 mph doesnt matter what gear its on. If I use D mode or S, i don't get it as often, maybe once a month. The thing is fuel cut with tip, I can never get out of it unless i shift back to D mode and pray.[:@]
Old May 10, 2007 | 11:38 PM
  #24
falcompsx's Avatar
ORIGINAL: A3Night
Fuel cut!!!
Welcome to stage II [:'(]
is this a'normal' thing for stage 2?
Old May 11, 2007 | 01:37 AM
  #25
Audinam's Avatar
SoCal Crew Member
[sm=dontgetit.gif]
Old May 11, 2007 | 02:39 AM
  #26
odroggy's Avatar
hahahaah
yes
its over boost protection
it kicks in in my case if i try 2 to 3 times in a roll to push in a 6 gear padel at 1800 rpm and hold it it is the max boost about 23,24psi
and if you do it to offten it will protect turbo from overspining so caled "lean mode"
no worrys just keep it high rpm watch your boost
if you pai attention to it it will never happen again
[8D][8D][8D][8D]
Old May 11, 2007 | 12:29 PM
  #27
Audinam's Avatar
SoCal Crew Member
maybe that's it, cause i was gunning it from the traffic light 1st, 2nd, 3rd, 4rd, 105mph, no problem, 5th was when that split second shrug. i should just get the K04's and get it over with huh? hee hee.
Old May 14, 2007 | 02:14 AM
  #28
odroggy's Avatar
yeah good idea get G28t
WolfgangCarCare
Nov 24, 2014 03:51 PM
mattrazzo
Feb 20, 2011 03:44 PM
MK1_TT_Quattro
Jun 27, 2009 05:29 PM
nvus1too
Mar 25, 2007 02:39 AM
StepUpProductions
Feb 13, 2007 02:53 AM
