APR Heads Up
Old Jan 19, 2006 | 08:29 PM
dscott's Avatar
Default APR Heads Up
I have previously posted that I have the APR Chip and Exhaust. They have a problem. Set up with and without exhaust is made to run rich. APR did this because Turbo has more potential than fuel delivery system and they did'nt want car to lean out (safer to run rich). Too much air and not enough gas! Before the 2.0T they had opposite problem. This has caused car to run ruff after brief idle time. They have a program fix and fuel system upgrade comming (I am told and HOPE). Above is my "non mechanic" minds explanation. I just drive em folks!
The good news is our turbo has a lot of power potential. Bad news is you will have to buy upgraded fuel pump / injectors? I am sure APR can market this as STAGE II.
Will keep you informed.
Old Jan 20, 2006 | 08:27 AM
BadLuckAudi's Avatar
Default RE: APR Heads Up
You would think that they could just rewrite the programing to make it better not have to pay a bunch more for extra stuff
Old Jan 20, 2006 | 01:42 PM
Jestnomen's Avatar
6th Gear
Well the fuel system can only put out so much fuel. At some point you have to upgrade the parts. This is a real problemw ith tuning the 2.0t. I've seen at least one other tuning company offer a fuel rail or pump upgrade (can't remember part or company btw).
Old Jan 20, 2006 | 08:12 PM
AudiTech04's Avatar
That doesnt make a whole lot of sense considering the pressure the system runs at you would think all that had to be changed is the injector 'on' time
Old Jan 20, 2006 | 08:25 PM
dscott's Avatar
In all fairness to APR. They told me they will have a "patch" for program in a week or two but.....stage II fuel delivery upgrades are on the way.
Old Jan 20, 2006 | 10:51 PM
Quartz05's Avatar
ORIGINAL: AudiTech04
If you change (lengthen) the injector "on" time you're simply changing the duration of the fuel pulse. At high engine speeds (read: high reciprical velocities) a lengthened fuel pulse would be less efficient because it would be delivering a portion of its payload either too early or too late in the stroke.
Old Jan 30, 2006 | 08:33 PM
buckofbox's Avatar
does this problem still apply to the chip when it is set for 91 octane fuel?
or isa it only when using the premium mode?
R-bo
Dec 25, 2010 04:05 PM
domino877
Feb 19, 2008 12:44 PM
cvacc411
Dec 9, 2006 12:36 AM
rbrtech
Nov 11, 2006 08:38 PM
streetstruckk
Aug 19, 2006 07:12 AM
