Audi A3 2001 1.6 Petrol - Clunking & Loss of power
Old Apr 20, 2017 | 08:25 AM
JamesRen's Avatar
Default Audi A3 2001 1.6 Petrol - Clunking & Loss of power
Hi can anyone help me out, bought an old audi A3 2001 1.6 Petrol for a run around this summer and 6 days in its causing problems!
Im getting up to around 4th gear and there is a grinding/ thud noise and it loses power and the transition light is flashing, then it will go and the light will just be constant.
As soon as i have slowed down and re started the car its fine for a while then it happens again.
Its almost like the car is pulling back and as the accelerator goes down it makes a scraping noise (almost like the noise it would make if the brake pads were non existent). the initial pull back is quite violent (like dropping down a gear or two but after that you could continue.
has anyone has the same issue or can help me out with knowing what it is?
Cheers
James
Old May 5, 2017 | 07:52 PM
Shadowfax's Avatar
Cheers
James
I had the same problem for my 05 A3 did you get it fixed already? Or do you still need an answer?
steven.whyte
Mar 15, 2012 11:53 AM
DonnaC5
Nov 5, 2008 05:46 PM
tgsworldwide
Sep 10, 2008 07:37 PM
