bulbs
Old Mar 26, 2009 | 11:16 PM
spaceman3's Avatar
Default bulbs
I've had two front parking lights go out on me within a couple of months. I thought it would be under warranty, but I'm at 20,000 miles, and the dealer says it 12k or 1 year and under for it to be covered. Is this a common thing with the A3 that you're all also dealing with? It's $1.50 for the bulb and $48 for labor to have to changed, and I'd love to do this myself if someone told me how simple it was...
Old Mar 27, 2009 | 04:23 AM
L7's Avatar
L7
If it's for any of the rear lights - it is easy. I've replaced a brake-light already and was amazed at how simple it was. The procedure for getting the assembly off is in the manual and there is a tool with all the tire change stuff. It's not worth $48 dollars.
Old Mar 31, 2009 | 11:53 AM
krazyboi's Avatar
You talking about the side marker bulbs? Or the ones in the headlight housing?
Old Apr 1, 2009 | 04:13 PM
a3_yuppie's Avatar
SoCal Crew Member
If he means the parking light, that is the orange thing in the bumper. That is according to the A3's instrument panel display. You can use VAGCOM to get more infor, i.e., front or back.
KB, I tried to do it your way (press on bumper and the pry it off), but didn't have your skills, and had to use a flat head screwdriver to help. The passenger side was easy but I bent the cllip on the driver side; luckily, I bent back, and it snapped into place just fine.
Old Apr 7, 2009 | 06:49 PM
rollyfoster's Avatar
i was just about to do a search on this. my rear brake light is out. i can just get a new bulb and do it myself? nice!
Old Apr 8, 2009 | 10:01 AM
krazyboi's Avatar
spaceman3. If it is the orange bumper lights like suggested...here's a video I made of how to remove it. http://s76.photobucket.com/albums/j1...t=3481dfe1.flv The bulb is removed from the socket by pulling it straight out. If not, slight twist and pull.
rollyfoster...which bulb? The center or one of the tail light bulbs? Yes, you can do it yourself. For outer lens: http://oooo-a3.blogspot.com/2006/08/...mber-turn.html
Old Jul 16, 2011 | 10:47 AM
eliu36's Avatar
That seems very easy. Are we talking about the same bulb? In the attached pic, it's the orange light on my 2007 A3.
Old Jul 16, 2011 | 10:58 AM
eliu36's Avatar
KrazyBoi, where were you these 4 months! I just took the bulb out according to your 9s video. It took me 4 months to figure it out!
generik777
Jun 6, 2008 10:36 PM
ryuujin
B7 Models
Jun 6, 2008 06:29 PM
93Akkord
Nov 29, 2007 01:42 PM
foorausfoora
Jun 9, 2006 12:29 PM
