Condensation gunge on oil filler cap A3
Old Nov 24, 2008 | 08:07 AM
williamgrierson's Avatar
Default Condensation gunge on oil filler cap A3
I have got condensation gunge under the oil filler cap on my A3 ..07 Reg..special edition. Granted there are days when only short journeys are inevitable, but would be grateful for advice /ideas and action I should take.
Car performance excellent, no oil in coolant.
The only thing that might have to be taken into consideration is that the vehicle had very little use for 3 months after it's service at 14,000 miles. Total mileage is now 16.500.....
Any advice most welcome...
Old Nov 24, 2008 | 12:19 PM
dana3's Avatar
Clean the oil cap. Give it good run up motorway recheck cap.
Sound like just needs good run to me.
Old Nov 25, 2008 | 04:30 AM
Good advice....you are right. I am keen to try the simple things first and I also want resolution on this whilst vehicle remains in manufacturer's guarantee
What however might you advise if that doesn't work? or --put it another way-what shall I tell the dealer to check--since I am trying to avoid a conversation with a defensive service dept along the lines of them saying "They all do this--it's normal" , "never do short runs" , "we will check it when it next comes in for a service" sort of unhelpful delaying tactics.....
Old Nov 25, 2008 | 10:12 AM
byrun's Avatar
Had the same problem on a air cooled VW Beetle. My commute was 2 miles and it never got hot enough. Also check make sure your PCV valve is working. After that it gets serious.
Old Nov 25, 2008 | 12:35 PM
dfrost's Avatar
If that's the 2.0T FSI engine, the "grunge" is the primary indicatror of a problem with the PCV system, which has been the subject of numerous updates. I believe that VW/Audi is up to Rev. F of this part, which is attached to the intake manifold. It is relatively easy to get to. Eurojet makes an aftermarket inline valve that helps, too.
Here's a good blog describing the problem and solutions:
http://oooo-a3.blogspot.com/2008/03/...jet-valve.html
kjopen
Apr 30, 2013 02:56 PM
Jamesy281
Feb 18, 2009 11:42 AM
Pure_Xaos
Jan 14, 2009 08:53 PM
shortyxc
Dec 3, 2008 10:22 PM
VitaminB6
Oct 26, 2006 03:42 AM
