Coolant warning when engine is cold
Old May 17, 2010 | 09:25 PM
Jakethesnake19's Avatar
Default Coolant warning when engine is cold
Does anybody who owns an A3 have this problem... My coolant light comes on for the first 30 seconds after I start the car when the engine is cold.
Shortly after the first 30 seconds, the beeping stops and light goes off. This is the only problem I have with no other symptoms.
I checked the coolant levels and they appear fine.
I was thinking that the level might be alittle low and the light goes off after the water/coolant expands when the engine warms up.
The dealer said not to worry about it last time I brought it in for service. I would assume that they would top off the fluids during the servicing and I still have this problem.
Again, thats the only issue. Im thinking of adding a little bit of some distilled H2O, but not to get the coolant/H20 mixture off.
Will update after I add the H20, just thought Id post to see if anybody else has this wierd problem.
Thanks
Old May 17, 2010 | 10:05 PM
bbbobbb's Avatar
Yup, '08 A3. The tank looked fine and full to me. Once heated up the light went out. The sensor must be right at the line. I told the dealer and they added a little more coolant to the overflow tank. This stopped it.
shipo
Feb 8, 2015 04:52 PM
tdoyle
Sep 16, 2009 04:48 PM
moreldav
Jan 25, 2009 10:25 AM
03A41.8T
Oct 24, 2007 10:55 PM
PMONT
Mar 22, 2006 01:31 PM
