DV problem
Old Apr 29, 2007 | 08:14 AM
odroggy's Avatar
Default DV problem
I am constantly blowingDV on my A3 any body solution for it please help!
since i did upgrade to stage 2 REVO with all 3" sys intake exhaust and it runns full boost
it took me only 4 days to blow 2 DV's
Old Apr 29, 2007 | 01:03 PM
Chef's Avatar
Default RE: DV problem
Do you have a boost gauge, and if so, what are your boost spikes?
The best option if everything is running correctly is to go with a mechanical DV so you won't burst the rubber diaphram any longer. Currently Eurocode Tuning is the only one with an option on the market, but it runs off of a vacuum line. Forge is coming on the market soon with an electronic, mechanical valve, which might be a better option. I have the Ecode version and it works great, although the DV sound has changed some, and I've lost 1-2 lbs of boost at times.
Make sure that you are boosting correctly before changing to the mechanical DV. It would suck to apply a patch to a symptom, only to have the disease get worse and break something more valuable, like the turbo.
Cheers!
Old Apr 30, 2007 | 03:05 AM
odroggy's Avatar
thanks man
how many psi are you running now
no i do not have boost guage about to install one but didnt found nice pad for the A pilar
do you have any sugestions where to look for it
and by the way how bad was your rack?[&:]
is your car done yet
cheers
Old Apr 30, 2007 | 12:59 PM
Chef's Avatar
ORIGINAL: odroggy
thanks man
cheers
My boost will spike to 16-20lbs, depending on the gear and rpms. It will hold about 1-2psi lower than that. Ideal conditions in 6th gear starting at 2krpms WOT, thenit will spike to 20lbs and hold 18lbs until about 4krpms, then slowly tapper off. Of course, by the time the boost is tappering off in 6th gear, you're well into the triple digits.
The wreck wasn't too bad for the most part since the car is repairable and I'm walking and talking. I have some whiplash injuries, but otherwise all is going well. Hoping to have the car by the middle of this week.
Cheers!
Old May 1, 2007 | 02:59 AM
odroggy's Avatar
hey chef is that on your grill S3 badge and the collor is blue right?
it looks exacly as my car have all that just 2" lower
thanks budy
i ll let you know how it goes after i put all thoes little extras on
need to put a pic on the web
boost up!!!!!
Old May 1, 2007 | 12:38 PM
Chef's Avatar
Yeah, I asked them to put on the S3 front, but we'll see.
I have way too much wheel gap, but luckily, I have a set of Koni coilovers on the way. That picture is a little older anyway, so I'll post up a new and refreshed car soon.
Cheers!
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
