Glow plus relays - HELP
Old Aug 7, 2007 | 12:49 PM
byrlord's Avatar
Default Glow plus relays - HELP
My A3 1.9TDI 110HP has the common problem with the glow plugs.
Reading the forums someone suggested to change the glow plugs relay.
How can I find which one it is (some one said it is 109 and 103??) and more important ... is there a way to test if it is broken or not ?
All the best,
B
Old Aug 7, 2007 | 01:21 PM
techbod's Avatar
Default RE: Glow plus relays - HELP
# if the glow plug light goes off the relay is ok so it might be the glow plugs and not expensive to replace
Old Aug 7, 2007 | 05:58 PM
antinet's Avatar
This is a description SAFETY-VALVE
http://www.fotosik.pl/pokaz_obrazek/...bcf7deaa0.html
Old Aug 7, 2007 | 09:47 PM
Chef's Avatar
I had a similar problem on my TDI and it was the harness. Check out the link for exceptionally good reading on the subject. It's on a 90hp 1.9L, but parts are mostly the same between the two.
http://forums.tdiclub.com/showthread.php?t=79819
Cheers!
Old Aug 8, 2007 | 10:54 AM
byrlord's Avatar
TOP MAN !
Cheers !!
Old Aug 8, 2007 | 09:47 PM
Chef's Avatar
Let me know how it works out for the 2.0 TDI.
Cheers!
Old Aug 11, 2007 | 04:04 PM
4RINGSROD's Avatar
Imagen a chiped 2.0 TDI think about the torque numbers. (example- chiped jetta TDI 1.9 is 150hp 245lbs) Now do that in a A3 with the new 2.0TDI we all would get our ***' handed to us and still stop at the pump first. Can't wait tell the US OIL A$$holes pull there heads out and let us get these increadible engines in the states. like the 1.4supercharged turbo
Old Aug 11, 2007 | 09:53 PM
Chef's Avatar
I would LOVE to have the 3.0 TDI in my A3. Imagine how that torque monster would run!?!
I can always dream.
Cheers!
Ozzy S
May 9, 2013 09:29 PM
AndyAudi16
May 22, 2010 08:11 AM
CLX
Jan 20, 2008 07:05 AM
kbuff97A4
Oct 1, 2006 05:32 PM
thintzen
Sep 20, 2005 04:23 AM
