Gunk build up on oil cap
Old Mar 10, 2009 | 01:16 PM
ChaoticBliss's Avatar
Default Gunk build up on oil cap
Hey everyone,
I have a 2008 A2 2.0 and when I take off the oil cap, there is a bunch of white gunk built up on it. I cleaned it all off and changed the oil and then checked a while later and the gunk is back. Any idea what this is? Is it normal?
Thanks
Old Mar 10, 2009 | 01:17 PM
hcaudikeed's Avatar
i believe that's normal condensation buildup.
Old Mar 10, 2009 | 01:47 PM
byrun's Avatar
If you don't drive it much then there is not enough heat for a sufficient amount of time to blow this condensation out. I had this problem on a air cooled VW a long time ago. If this is not your case then you have an issue where water is getting into your oil. Most likely a head gasket or worse. Have it checked soon to be sure.
Old Mar 11, 2009 | 08:46 PM
ScottTBurg's Avatar
Default Gunk Build Up
Some build up like you mentioned is natural. My '07s been doing it since it was new, just a little white gunk on the oil filler cap. There was a long thread about this several months ago, you may want to check it.
D.B.A.
Jul 2, 2009 01:59 AM
Threeputt
Feb 13, 2008 10:40 PM
IceRhine
Mar 23, 2006 12:00 AM
mikehh
Feb 21, 2006 12:30 PM
A4Sooner
May 6, 2005 07:54 PM
