Help! Quick IPod integration question
Hey everyone!
I am new to the Audi forum and I have a basic question.
I am going to install the factory Audi Ipod kit into my 2006 A3. I have been reading many of these posts but having trouble following exactly what to do (manual instructions are fairly vague).
I have pulled the glove box shelf out, and I have descovered an 8-12 Pin Female connector attached to the box.
This connector does not connect with the Audi Ipod converter box. I am assuming this harness and connector is for a CD changer (which I do not have)? Does anyone know if I can use this existing harness? If so how does this connect, since none of the included harnesses (kit) match to the existing one?
Or does this exisiting harness just need to be replaced by one of the new ones that came in the kit? If so I assume that my only option is then to pull the stereo out of the dashboard for this.
Thanks for the adivce
Yeah I just bought the Dice Ipod adapter from Enfig.com.
http://enfigcarstereo.com/shopsite_sc/store/html/DICE_I_AUDI_T2.html
Going to return the Audi Ipod kit to the dealership, since it seems to be fairly un-intuitive.
This Dice Ipod kit seems to be the way to go after researching for a while. It has both the Ipod adapter/AMI (Audi Music Integration) feature, along with a stereo 3.5mm mini jack (head phone). All that and this particular kit mounts straight into the pre-existing CD changer wiring harness in the glove box.
So truly this should be plug and play, no pulling the radio and re-running a new wiring harness.
Hope this helps those looking for a better alternative than factory Audi Ipod Adapter.
~Clockwork
~Clockwork
Cool glad that helped. Didn't seem like anyone had laid out theoptions clearly. The Audi Ipod integration comes with only harnesses that you will need to run and install directly in back of the radio. Unless you know the pinout, tying into the CD changer will be very difficult. I will let you know how the Dice Adapter installs once i get it next week, it should be pretty simple. I will be sure to post plenty of pictures too.
~Clockwork
~Clockwork
Didn't see the identical Grom adapter. The only Grom interfaces I found were either Ipod Connectors or stereo 3.5mm connectors. I didn't see a Grom that had both connectors. If you have a link for an adapter with both inputs please share.
ORIGINAL: Clockwork
The M.O. for any of these kits is apparently the the same, once installed correctly. All speakers work right, the stereo turns off after removing the key and the wheel controls work the same as they did for the radio.
Note that unless you have 5 or fewer playlists, you are far better off leaving the CD selector on CD1 ("basic mode" according to Grom) and choosing playlists directly on the IPod.
I've got the 2008 A3 S-line (no Nav or BT
) with the iPod intergration in the glovebox. this is great and all but I have an iPhone. Obviously I *could* plug it into the glove box but that kind of defeats the purpose of having a phone. I can hear it ring if a call comes in but I can't answer it.
What is anyone doing in a situation like this? I have a 2-Gig Nano as well that I will be loading up with songs and it'll just stay in my car at all times but I'd stlii like to figure out a way to get my iPhone to work with my car or am I just dreaming at this point?
I'd have got the Nav and BT if I could have but this is a company program car so I really had no choice in what I got. I was lucky enough for it to have the S-Line and it's Black on Black with the Open Sky System so I'm not complaining.
Maybe after my year in this car is up I'll try to get what I really want in an A3!
) with the iPod intergration in the glovebox. this is great and all but I have an iPhone. Obviously I *could* plug it into the glove box but that kind of defeats the purpose of having a phone. I can hear it ring if a call comes in but I can't answer it.What is anyone doing in a situation like this? I have a 2-Gig Nano as well that I will be loading up with songs and it'll just stay in my car at all times but I'd stlii like to figure out a way to get my iPhone to work with my car or am I just dreaming at this point?
