High end audio
Old Jun 18, 2007 | 02:12 AM
NimaA3's Avatar
Default High end audio
Hey guys, its Nima...lost my password so had to register again. But i have a quick question it seems that my audio cant be sold, and i want to keep the stock deck. is there anything i can do that wont pass dirty music to my amps and speakers without changing the deck and keeping it stock? purpose of a deck is to filter music, and since high end audio equipment cannot take abuse what so ever, i dont want to risk it.
Old Jun 18, 2007 | 09:28 AM
Chef's Avatar
Default RE: High end audio
There are many different signal processers. Here's one:
http://www.crutchfield.com/S-bsnGE3E...p;I=5753SIXTY2
Cheers!
Old Jun 18, 2007 | 05:42 PM
BAMF's Avatar
Take a look at the diagram here:
http://forums.audiworld.com/tt/msgs/63403.phtml
It is for a TT, but the head units in the A3 have the same connections. The stock unit has pins for line out signals. Dependent upon your head unit, the harness should already have either rear L/R and sub (Audi Concert) or front and rear L/R and sub (Bose). If you are handy with a soldering iron and don't mind cutting up your stock harness, you could add RCA connectors and then use aftermarket amps and speakers. This would give you the cleanest, best quality signal possible from the stock head unit.
Also, I have been emailing a guy from Metra, a company that makes harnesses for aftermarket head units, about putting something together for the A3. Since the stock harness uses standard Audi/VW connectors, it shouldn't be too hard to come up with something that would provide RCA line outs without cutting anything. I will run it past him and see what he thinks.
Old Jun 18, 2007 | 10:44 PM
Chef's Avatar
The other problem is to get a "pure" signal coming from the deck. The stock unit will cut bass with increased volume and you're best off getting the unmodified signal out to a processor so you can tweak the sound on your own.
Good luck and let us know. This will be a mod coming somewhere down the line for me.
Cheers!
Old Jun 18, 2007 | 11:39 PM
Monkeyboy's Avatar
There's an old saying in audio... garbage in - garbage out. Be careful of adding signal processors that might just mask true good audio.
ndinsmore
Sep 22, 2013 09:36 AM
guest196826
Nov 25, 2011 07:36 PM
Turbo4me
Jul 22, 2010 04:55 PM
DJShock2000
Aug 12, 2005 06:53 PM
