Hou to dip rt side mirror?
Try the following it should work.
Put the car in reverse. Adjust the right mirror down to the extent you want it to be when in reverse. After setting, turn mirror selector back to lock. It should remember your setting each time you are in reverse, but revert to the normal setting when you return to drive.
Dipping mirror
Set it up as you would expect:
- Put car in reverse and adjust he mirror as low as you want it when in reverse.
- Do not move the remote setting from the right mirror (do not put it in lock or other settings)
If there is anywhere on personalized settings to change that so it will operate all the time regardless of what is selected, I have not been able to find it. I am wondering if this is normal for all the A3s, or just the Cabs. It certainly does not make any sense in a car that is otherwise well thought out.
lilman05
08-27-2006 07:42 PM
