Key stuck
Old Apr 26, 2020 | 01:24 PM
Ryan Dale's Avatar
Default Key stuck
Hi I'm Ryan,. I own a audi a3 2.0l tdi sport. It has developed a problem where my key is stuck in the ignition and no matter what I do I cannot get it out. Any advice on what my next step is as I have sprayed it with wd40 and that has had no effect.
Old Apr 27, 2020 | 07:37 PM
Redneck Slim's Avatar
Does the key rotate through the different positions? Will it lock the steering column,start the engine,etc.?
Old Apr 28, 2020 | 10:14 AM
Ryan Dale's Avatar
Default Key
It is stuck in the "ignition on" position it will start the engine if i disconnect and reconnect the battery. It will not lock the steering lock and it will not turn the car off. It happened when i put the steering lock on. It got stuck in the "off position" and i managed to get it to turn to the "ignition on" position. I just haven't been able to get it to go back to car off position and it will not come out
Old Apr 28, 2020 | 12:27 PM
A common problem with mechanical steering column locks is they partially jam because the front tires are exerting some side pressure on the steering column. The usual solution is to jiggle the steering wheel side-to-side while turning the key. If that doesn't work you are probably looking at something expensive.
Carl & Kathy
Dec 24, 2012 04:02 PM
altonachrome
Jul 14, 2010 11:08 AM
a4jon
Apr 23, 2010 04:52 PM
a4nick
Nov 3, 2008 01:13 PM
kevinpunzalan
Feb 14, 2008 01:13 AM
