Oil Consumption
Old Aug 25, 2007 | 03:07 AM
ace2525's Avatar
Default Oil Consumption
Got a 2006 with DSG, I go through 1litre every 1500 miles or 2400 km. Asked Audi, they said "it was within the acceptable tolerance". It has only 20000K's on it, does this make sense? I'm worried about longevity.
Old Aug 25, 2007 | 09:14 AM
A3SL.MAN's Avatar
Default RE: Oil Consumption
Hello ace2525,
It appears oil consumption is a known issue as there is arready a discussion on this topic that began on 6/30/2004. The most recent post (end of 3rd page) was 7/30/2007.
[ul][*]A3 Newbies Info Link: https://www.audiforums.com/m_547598/tm.htm[*]Direct link: https://www.audiforums.com/m_7326/tm.htm[/ul][align=left] [/align]
Old Aug 25, 2007 | 10:09 PM
auditech79's Avatar
Change the pcv or puck valve, those always get plugged on the 2.0T motor. Its located under the engine cover on top of the engine.
Old Aug 26, 2007 | 01:24 PM
A3SL.MAN's Avatar
ORIGINAL: auditech79
Sounds like a good tip auditech79!
[ul][*]Is the puck valve another name for the positive crankcase ventilation valve? Or are they 2 different valves?[*]How often do they typically need to be replaced?[*]Why do they become plugged so frequently?[*]Why does a plugged pcv or puck valve increase oil consumption?[*]Should ace2525 be concerned about the "longevity" of his 2.0T motor?[/ul]Thanks!
Old Aug 26, 2007 | 02:41 PM
MexA3's Avatar
WOW...I have 7 500 kilometes in my 2007 DSG and never had changed the oil, hte oil level still very good and the computer hasnt told me to do it so, I think you must have a problem
Old Aug 26, 2007 | 07:30 PM
falcompsx's Avatar
My car burned a full quart on the last oil change(oil from audi service). I changed it myself this last time with Torco Racing synthetic oil, it is VW501.whatever approved, so no warranty issues and it hasn't burned a single drop in 3000miles, and thats including day at the track, driving hard enough that my exhaust melted my rear bumper a bit. I will not use anything else in my car ever again.
Old Aug 26, 2007 | 09:43 PM
auditech79's Avatar
ORIGINAL: A3SL.MAN
Thanks!
Well to answer all of your questions, the 2.0T engine is built with extremely tight tolerances, which means there is almost no leaks in the PCV system. If you take off the oil cap and start the engine it will almost be miss-firing because the computer is desinged to see a very low amount of air escaping.
With that being said a lot of crap gets passed through the PCV valve and often clogges it, when it gets clogged pressure gets pushed into the crankcase and works it way under the piston and eventually burns it off through combustion increasing oil burn off. Running a seafoam treatment through the oil every 40k should help relieve these symptoms.
Juddsmith
Sep 24, 2014 11:05 AM
whoisthis
B7 Models
32
Nov 16, 2010 04:43 PM
wallj
Feb 7, 2010 06:50 PM
vjreddy
Jul 25, 2007 04:15 PM
ou51
Dec 24, 2006 12:33 PM
