Please help!!!! Audi A3 loosing coolant
Old Mar 27, 2012 | 05:14 PM
scottkelly85's Avatar
Default Please help!!!! Audi A3 loosing coolant
Hi People,
I am hoping for a little help here.
I have a Audi A3 2.0fsi 2004 plate 48k miles. I have noticed i am losing quiet a lot of coolant recently. I am having to top it up every 3-4 weeks. I took it to the local garage after reading on the net this could be a gasket problem. They could not find any signs as to why this is happening. They told me to just monitor the problem. (big help) I have no power loss , no sign of any form of leak inside the car, or underneath. I left the car running for 1 hour put carboard down and not 1 drop came out and not a sign of my coolant level dropping. I have checked the oil cap and no sign of the yellow/browney gunk. It seems as its only happening when the car is being driven. The temperature is fine and the car runs great. I am really stuck at this point as to what to do. If any of you have any suggestons or maybe point me in the right direction at what this could be i would be really grateful.
Old Mar 27, 2012 | 05:18 PM
M5S5's Avatar
Tech Certified
The cooling system should be pressure tested. If no visable leaks are seen then a cubustion leak test should be performed.
Check the floor boards in the car also. Have seen leaky heater cores leaking down under.
Old Mar 27, 2012 | 05:22 PM
Thank you very much for your input. My car is booked in for a pressure test on saturday. i did notice when i was giving it a clean that the floor in the back of the car (behind driver seat) was slightly damp in 1 place.
Old Apr 3, 2012 | 06:21 PM
pdxjim's Avatar
Last year in my 3.2 A-3, I had to add coolant. I never saw a leak or smelled anything. When I took the car in for normal service, they found a bad thermostat and that was replaced. No problems since then.
Old Apr 4, 2012 | 08:12 AM
Thank you pdxjim,
I had a pressure test done on saturday and nothing was found. How much would it cost me for a new thermostat fitted approx. It might just be worth having it done.
Old Apr 4, 2012 | 09:24 AM
M5S5's Avatar
Tech Certified
Why would you replace a good thermostat. If the seal is leaking then yes also replace the thermostat but i would leave it alone unless it is causing a problem.
Thermostats do not leak unless they are part of the housing. They are a internal part of the cooling system.
Old Apr 4, 2012 | 07:37 PM
pdxjim's Avatar
The thermostat work was about $550. The coolant was leaking out and then vaporizing and so I never saw a leak. It was quite evident I guess when looking from underneath with all the residue that had built up from the leak. Naturally I was out of warranty about 6 months when discovered!
Old Apr 4, 2012 | 07:55 PM
M5S5's Avatar
Tech Certified
Sorry , i was referring to Scottkelly85's post. He made it sound like that would fix his problem without actual proof. I like to figure stuff out before replacing parts.
Old Jul 8, 2012 | 05:54 PM
Sorry people for my late reply.
The problem turned out to be my water pump.
Thank you for your help and input.
Old Aug 24, 2012 | 08:30 PM
boywonder's Avatar
i'd rather place a thermostat than a water pump. that must've been an expensive repair.
CSB51
May 26, 2015 05:23 PM
bboylawless
Oct 20, 2014 09:51 PM
tlbjornson
Aug 22, 2014 02:16 PM
cobrad4
Jul 26, 2011 11:52 AM
legends99va
Dec 1, 2008 11:41 PM
