problems! please help!
Old May 17, 2006 | 11:25 AM
groovekid2010's Avatar
Default problems! please help!
ive just bought an a3 and got a problem already! when i shut the doors, they dont shut properly they both seem to bounce open abit, then you have to either pull them shut from the inside or push them shut properly from the outside. does any one know why this is? also, the central locking doesnt work from the drivers side?
any advice would be appreciated.
thanks
Todd
Old May 17, 2006 | 04:20 PM
Audinam's Avatar
SoCal Crew Member
Default RE: problems! please help!
TAKE IT TO THE DEALER!!!!!!!!!!!! YOU SHOULD HAVE A WARRANTY!!!!!!!!!!!!!!!!!!!!!!
Old May 18, 2006 | 04:16 AM
Chef's Avatar
Ditto!!!
Old May 18, 2006 | 10:34 AM
techbod's Avatar
I think it wise to check if the car has been in an accident
Old May 18, 2006 | 06:31 PM
Jex's Avatar
Jex
Try it with a window open - it could be that it's just the air pressure inside the car causing the doors not to shut properly. I tend to find this happens a lot with VWs/Audis because they're made well enough to be semi-airtight. If so just close them a bit harder.
Obviously if you still get the problem with a window open, it's probably more serious so head for a dealer.
Old May 19, 2006 | 01:33 PM
crusader's Avatar
Was it out the box or perviously owned.....If new......straight back to dealer!!
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
