Remove Engine Cover
Old Aug 10, 2008 | 04:22 PM
ScottTBurg's Avatar
Default Remove Engine Cover
How does one remove the plastic engine cover to replace the air filter? I can usually figure anything out but this has me stymied. I can see where the air filter is nestled. I unscrewed the knurled nut on the front left, removed the two screws on the right side, removed the air intake and outake connections but still couldn't loosen the engine cover. What's the secret?
Thanks in advance for someone's help.
Old Aug 11, 2008 | 01:27 AM
4RINGSROD's Avatar
It's actually really easy. in thought its easy. you need to grab the two sides and just yank as hard as you possibly can. The rubber grommets that hold in down are very tight. Then you have half a dozen screws that you have to remove before you get to the air filter.
Old Aug 11, 2008 | 07:58 PM
ScottTBurg's Avatar
Thanks. I'll try it and will yank hard.
Old Aug 11, 2008 | 09:15 PM
a3booster's Avatar
Yeah. you wanna disconnect your MAF sensor in the top left and undo the 2 metal clips as well. Be sure to undo the intake hose with a big set of large mouth pliers. There is one grommet in each corner just about. I usually pull on the right side first. ( it seems to be easier ) If the rubber grommets stay on the engine take them off and put them back on the cover. It wont sit right if u dont, or it will be a big pain to make it sit right.
Old Aug 13, 2008 | 05:31 PM
ScottTBurg's Avatar
Thanks for the lead. The engine cover came off with a good yank at each corner. I lubed it with silicon so next time perhaps it will not be as difficult to remove.
Cheers, ScottTBurg
a3driver33
Aug 1, 2009 05:16 PM
Munzter
Jul 22, 2009 08:16 PM
fcaracol
B7 Models
Mar 28, 2008 01:47 PM
A41.8TQATL
Aug 13, 2005 04:34 PM
aho
Jun 17, 2005 01:45 PM
