Slight movement after put in park position.
Old Jan 10, 2008 | 02:36 AM
mklim's Avatar
Default Slight movement after put in park position.
I have had my 2007 2.0 DSG A3 model for about 3 months now. Whenever I put the car in Park on a slightly sloped drive way or surface, I notice the car would slide backwards a bit after I lift my foot off the brake pedal. The only way to prevent this from happening is to apply the parking breaks before I lift off my foot. Is this normal?
Old Jan 10, 2008 | 02:58 AM
fusionx's Avatar
Default RE: Slight movement after put in park position.
Yea I think its normal, just slides back a little more than most cars ive driven. I also get a roll back when I park in my driveway but ive got used to it by just easing the break after its in park to when it stops. So it might just develop into a habit for you too haha
Old Jan 10, 2008 | 07:48 AM
Chef's Avatar
Remember, the DSG is truly a "manual" car with dual clutches. If you leave your manual car in gear on a slight incline, it will roll a little back too as the car engages the gear. I would definitely use the parking brake at all times when parking. Like was said, it is just a good habit to get into.
Cheers!
Old Jan 10, 2008 | 08:20 AM
railrunner's Avatar
also put apply the e brake while in neutral, let it roll into the e-brake, then put in gear. Less stress on the gear.
Old Jan 10, 2008 | 11:31 AM
Swaynest's Avatar
I had the same thing happen but it rolled forward a little. I used to never use my parking break but i found it helps alot.
Old Jan 10, 2008 | 12:03 PM
drumdork03's Avatar
Yep, normal, but watch out if stopped at a steep uphill intersection. Best to tap the brake once and thenimmediately step on it again to enable the hill hold assist. Had I not read about this on the forum here, i would have rolled my brand new car into another while driving off the dealer lot for the first time!
Old Jan 15, 2008 | 11:27 PM
mklim's Avatar
Everyone, thanks for your comments. Sounds like I should start using the parking brakes.
railrunner, What is e-brake?
Old Jan 16, 2008 | 12:01 PM
dfrost's Avatar
I always use the parking brake when parking. Definitely a must-do on the many steep hills of Seattle.
Old Jan 16, 2008 | 03:18 PM
17thfloor's Avatar
ORIGINAL: mklim
parking brake = e-brake or emergency brake
Old Jan 16, 2008 | 04:09 PM
mklim's Avatar
e-brake = emergency brake. I should have thought of that. I thought is was some kind of electronic brake that I am not aware of. Thanks for the clearification.
Peterhopson84
Aug 20, 2013 09:57 PM
A6fl
Jan 6, 2013 06:45 PM
pdxrado
Sep 6, 2012 03:38 PM
Luis Cavaco
Mar 19, 2006 07:49 PM
