sport to drive
Old Oct 11, 2006 | 04:14 AM
seefathand's Avatar
Default sport to drive
is it suggested/recommended to switch from sport mode to drive when the car is in motion? i like driving in sport mode alot, but sometimes when i turn onto the highway, i don't want it to be stuck at such a high rpm for so long to conserve gas. so would it hurt the car if i just shift into drive mode?
Old Oct 11, 2006 | 03:34 PM
BearTrap's Avatar
Default RE: sport to drive
No, it won't hurt anything to switch back and forth as needed. I have found it advanageous to start out in sport when I need power and shift to drive once I've gotten to my cruising speed.
Old Oct 11, 2006 | 05:55 PM
falcompsx's Avatar
you could always just tap the paddle shifter to upshift once on the highway.
Old Oct 11, 2006 | 06:25 PM
BearTrap's Avatar
ORIGINAL: falcompsx
I thought so too, and tried that the other day. I found that the car will go back to Sport (5th gear) on the least bit of throttle. It doesn't like to hold 6th gear in Sport mode unless the speed is much more than typical highway speeds.
Old Oct 11, 2006 | 06:36 PM
falcompsx's Avatar
I see, well thats what drive is for, and no, it wont hurt it one bit to shift back and forth to suit your current needs....
Old Oct 11, 2006 | 08:07 PM
a3_yuppie's Avatar
SoCal Crew Member
Yeah, after the reflash it's hard to start in D perfectly if you are in a hurry. If you press on the gas "normally", it tends to upshift a tad too quickly. If you nail the gas, you get some wheelspin.
Old Oct 16, 2006 | 07:34 PM
illwork4sumbread's Avatar
Man-it seems DSG is MORE complicated to operate than a 6 speed...
Old Oct 16, 2006 | 08:46 PM
stryker's Avatar
Hey workforsomebread when are you going to post some pics of your ride, interested on seeing that chin spoiler.
I switch from sport to drive lots of time, no need to worry mon.
Old Oct 17, 2006 | 04:29 PM
Good question...
I don't have a digi cam but I'm sure I can get a few up soon. I think you all will be surprised how agressive the kit is.
mof
May 14, 2014 05:22 AM
pimplikeness
B7 Models
10
May 31, 2011 05:40 PM
flipkid
May 30, 2007 05:44 PM
toysnob
Aug 27, 2005 02:13 AM
