Tune Time
Got a 2006 3.2 quattro w/ 63k miles. Never tuned anything - but impeccably cared for. I've got $3k to spend - what should i spend that money on to maximize performance?
Thanks in advance for the help on this forum.
H&R coilovers with V2 front spring not the V1
Front and rear H&R sway bars
HPA Haldex
HPA DSG flash(yes it will be readily available soon)
VF engineering motor mounts (yes all 3)
Forget the chip(but if you must...APR)
Forget the intake
Forget the exhaust
HPA Haldex
Forget the intake
Forget the exhaust
First of all to the OP congratulations - I have an 08 3.2 A3 Q and LOVE IT! Best car I have ever owned.
Second is regarding the HPA Haldex. What kind of upgrade is it exactly? Does it alter snow/inclement weather performance of the AWD? I go snowboarding quite a bit and don't want to sacrifice my winter weather safety.
The HPA Haldex is a controller upgrade that speeds up the transition from FWD to AWD, with increased torque transfer and more aggressive engagement of AWD mode.
If you want winter drivability, you should probably get yourself a set of 18" wheels (if you have 17" (and vice versa if you have 18" wheels) put summer tires on the 18" and some kind of aggressive snow tires like Michelin X-Ice and only use them for the winter season. Some people say the HPA haldex will cause the rear tail to slide out more. But as long as you got your foot on the throttle, you can keep on countersteering (with ESP off, of course, otherwise you hear the wheel chattering while ESP tries to bring the tail back).
I used my all season in the winter and they were pretty decent the first 10-15k miles in all year driving, but after the tread worn down a bit, they did not have the grip anymore following winter (still had quattro, so still could trash around in snow/ice).
Thanks for the reply - so no Exhaust? was thinking milltek - sounds the best to me.
TCardio - i can get all of that for $3k? What are best options - ordering products online then having dealer install (i'm way past my warranty and have good relationship w/ dealer) - or hit a tuning shop (Thinking Symbolic here in san diego)?
ClemsonKev
Aug 11, 2006 08:06 PM
