**UPDATE**My BOV on B6 1.8T**Throwing codes like a mofo
Old Dec 27, 2007 | 10:02 AM
  #61
nickellis14's Avatar
Default RE: **UPDATE**My BOV on B6 1.8T**Throwing codes like a ****
running too rich....sounds like a recirc problem. if he were sucking in air from somewhere else where the MAF weren't reading it wouldn't he be running lean? call me crazy.
Old Dec 27, 2007 | 11:56 AM
  #62
cincyTT's Avatar
I'm make believe
ORIGINAL: manhertm
Not accusing ,just asking. From what you posted it sounds like you installed it right. Plus there is a website that tested some diverter/BOV valves and said it did matter if you installed it backwards. Maybe it's the springs.
You can only install a bov one way. Also the spring was right. His problem is that he has a resiviour that he cant/wont remove so its causing air reading problems and throwing a cel.
Old Dec 27, 2007 | 12:43 PM
  #63
Papachristou's Avatar
does it do any good to chunk that boost res in my case?
Old Dec 27, 2007 | 12:47 PM
  #64
cincyTT's Avatar
I'm make believe
probably increase throttle response after shifting and move more air between shifts.
Old Dec 27, 2007 | 02:32 PM
  #65
umm, bump ^
"running too rich....sounds like a recirc problem. if he were sucking in air from somewhere else where the MAF weren't reading it wouldn't he be running lean? call me crazy."
anyone?!
Old Dec 28, 2007 | 03:57 PM
  #66
cincyTT's Avatar
I'm make believe
ORIGINAL: nickellis14
umm, bump ^
anyone?!
He doesnt have a recir problem, since he wasnt recir anything. The res was throwing off reading for the maf and the car went into soft limp since it thought something was wrong. Once the res is properly blocked off/removed, the problem will go away.
Old Jan 7, 2008 | 11:01 AM
  #67
patty AT forge's Avatar
I'm not familiar enough with the A4 to tell from the pictures posted, but there are two 25mm hoses running to the stock valve. The original poster installed the 004 in one and a 25mm plug in the other... are they correct? That is to say does he have the 004 connected to the TIP and the 25mm plug connected to his charge pipe?
Old Jan 7, 2008 | 12:45 PM
  #68
docurley's Avatar
Should have instaled it on the inlet manifold side and dumped or better still just pluged it off out of the loop so it was still there but not doing anything.
I run a Baileys twin piston on the inlet side for nearly two year without any issues but then I do not have the resiviour thing you guys have to have so it made life easy.
Here's some pic's of whats going on under the hood not great pic's but you will get the idea.
mestinville
Oct 25, 2013 05:05 PM
dollidarko
Oct 7, 2010 04:55 PM
Capo Cam
Nov 27, 2008 11:13 AM
Gobot
Mar 26, 2008 06:52 PM
philmeister
Jan 9, 2007 04:55 PM
