*Codes P0087 and P2293*
Old Dec 26, 2013 | 03:49 PM
theskater101388's Avatar
Default *Codes P0087 and P2293*
my dad got codes P000A, P0087, and P2293 on his '05 A4 2.0t with 97,000 miles on it about a month ago and decided to tell me about it now. took it out for a test drive and it feels like it has no power. it goes to a max of like 4k rpm and feels like the engine is really being held back and you can barely feel an acceleration difference whether i give it 1/4 throttle or WOT, if i held a full glass of water and floored it i wouldnt spill a drop, theres just no torque. i read about the cam follower issue w/ the HPFP and such and hoping it is not something too serious when i inspect it. I was just wondering if i take it apart and everything looks decent inside still(which im hoping), what would be the next step to look at? how would i know if just the HPFP is failing without any physical signs or how would i go about testing something like that? what would i look at afterwards..... do you think it could just be a really clogged fuel filter(never changed yet)?? i have a basic scan tool which shows me some live data and when i had it at idle and looked at Fuel Pressure on the scanner it was showing about 87-89psi. not sure where that pressure is being measured at in the fuel system though and if thats normal or not, i gave it a little gas and it hopped up to the 250psi range i believe i saw. i can always test again if needed though. any help/suggestions/questions would be appreciated, THANKS!!!
Old Dec 28, 2013 | 07:12 PM
CryptoStorm's Avatar
Fuel pressure regulator..
Old Dec 28, 2013 | 07:18 PM
Or fuel pressure sender. Maybe get a physical gauge and test
betyouaint
B7 Models
Apr 29, 2021 08:04 PM
JoeAudiA4
B7 Models
11
Dec 2, 2020 07:37 AM
highlinemotorworks
Aug 20, 2013 10:31 PM
Evilm0nkey
Mar 24, 2011 03:22 PM
joenelson7687
Aug 25, 2010 04:10 AM
