01 1.8TQ Idle adjustment
Old Mar 3, 2005 | 09:45 PM
sataie's Avatar
Default 01 1.8TQ Idle adjustment
hi, my car idles at about 600 RPM with a lot of valve noise (like a diesel), if the RPM is increased to about 750-800 it goes away. I can not find any adjustment anywhere. I have already changed the mass air flow meter and the idle control valve (idle stablizer valve). is there any way I can adjust the idle? thanks
Old Mar 4, 2005 | 01:13 AM
david9999's Avatar
Default RE: 01 1.8TQ Idle adjustment
Vag-com. you have to program it in.
You should also check for codes or vacuum leaks
Old Mar 8, 2005 | 01:11 AM
sataie's Avatar
hi,
no leaks, no codes
how do I reprogram? is this a dealer only option, or I can use the software diagnostic tool which allows me to hook up my laptop to the OBDII connection to read the codes? please advise.
Old Mar 8, 2005 | 01:18 AM
Jestnomen's Avatar
6th Gear
justinclarke
Nov 25, 2010 04:03 PM
Mean buzzen half dozen 08 A4
B7 Models
Jan 5, 2010 11:36 PM
Yentemad
Mar 13, 2008 04:16 PM
sdiegidio
Jul 29, 2007 08:46 PM
