'02 1.8T turbo question
Old Jan 15, 2008 | 02:53 PM
ToxicFormula's Avatar
Default '02 1.8T turbo question
Ok so I know I'll probably get flamed for it but I did a search and couldn't find a definite answere. So my question is, what turbo came stock on my '02 A4 1.8T. Is it a K03 or a K03s?
Old Jan 15, 2008 | 03:06 PM
cincyTT's Avatar
I'm make believe
Default RE: '02 1.8T turbo question
its still technically a ko3, but we all call it a ko3s.
Old Jan 15, 2008 | 03:46 PM
ORIGINAL: cincyTT
haha ok....so then which is it? is it called a K03s but its really a K03? is it the same K03 as on the 225TT's?
Old Jan 15, 2008 | 03:52 PM
cincyTT's Avatar
I'm make believe
its a ko3s.
But bw never made a "ko3s". Its an improved ko3 and the turners dubbed it "sport"
The 225TT's have a ko4-20/22/23 turbo
Old Jan 15, 2008 | 04:58 PM
Papachristou's Avatar
i would actually say its a hairdryer not a turbo but hey, we all have our perceptions
car should have come with a k04-015 like some people upgrade too but if u want power, go with a GTRS/GT28 series or real power some people are even going with gt3071r now
Old Jan 15, 2008 | 05:27 PM
chaos92287's Avatar
ORIGINAL: Papachristou
the k04-15 and the k03 in the b6's are practically the same, hence the reason why you have 1+ software available
Old Jan 15, 2008 | 06:36 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: chaos92287
THANK YOU!! As for gt3071r's, those things are great street size turbos. Fast spool and big numbers. Not really HUGE like some may make it out to be.
Old Jan 15, 2008 | 07:03 PM
indeed they are, just slightly larger opening (like .25 i think) and different turbines.... but the k04 makes a few (not many) more hp but if you compare the graphs
http://www.audizine.com/forum/showth...light=k04+dyno
it makes the power curve last longer... (of course its still not a BT but much better) someone else had a graph showing a 1+, 1+ and DSMIC, and k04 with dsmic and the k04 held about 30 ft lbs torque more throughout the powerband
Old Jan 15, 2008 | 07:12 PM
cincyTT's Avatar
I'm make believe
held 30ftlbs more because youhave one running ~20psi and the other running ~30psi
the only differnce between a ko4 and a ko3 is the 1-2mm increase on the turbine. The ko3s uses a larger inducer, compressor inlet, and a more efficient 8blade compressor vs the ko3 12 blade.
EvoTillIDie1
Mar 5, 2014 10:42 PM
98A498
Oct 12, 2006 08:06 PM
keko2004
Aug 30, 2006 02:44 AM
zat0rsk1
Aug 17, 2006 11:36 PM
west2005
Aug 13, 2005 06:46 PM
