03 A4 Acceleration Hesitation
Old Jan 5, 2007 | 02:21 PM
SacTown_Vlad's Avatar
Default RE: 03 A4 Acceleration Hesitation
Try to change your air filter first, if it didn’t help check sensor that is before throttle body. How’s your “check engine” light?
I had same problem with my 2000 A4 and had to replace that sensor few month ago
Old Jan 8, 2007 | 12:14 AM
BGoux's Avatar
ORIGINAL: AteUrV8
i had my throttle body cleaned and reset and it worked for about a day, and than went back to doing the same thing. it doesnt affect the speed of the car, just throttle response... if your in neutral does the car rev slower at some times than other times?
Nope, in Neutral the car acts normal. Also, when shifting w/ the tiptronic it not nearly as bad as it is when Auto.
Old Jan 8, 2007 | 12:15 AM
BGoux's Avatar
ORIGINAL: acetrebo
What year/engine/mileage is the car??
2003, 1.8T, 58,000. Just had a tune up done at 50,000
Old Jan 8, 2007 | 12:16 AM
BGoux's Avatar
ORIGINAL: SacTown_Vlad
Air Filter is pretty clean just replaced last oil change, Check engine light is not on.
Old Sep 3, 2011 | 06:39 PM
porschetech1111's Avatar
Originally Posted by BGoux
I had to replace the battery in my wifes A4 2 weeks ago. The dealer wanted $248, so I went and bought an Intersate Battery and did it myself.
Ever since I put that new battery in the car kind of stutters when you hit the gas pedal gently from the get go. Itwill also do it if you are traveliing say 45 mph, let off the gas and hit the gas gently. It will not do this if you get in the gas hard.
Thoughts? Do I need to reset the Trottle Body?
You must connect a VAG-COM and re-adapt the throttle body after battery removal, TB disconnect, ECM disconnect, Etc........
Old Oct 4, 2011 | 09:06 AM
Default Throttle body adaptation
You must hook up VAG-Com to adapt Throttle Body position sensor.
cori
May 10, 2014 12:05 AM
grockowitz
Nov 27, 2013 05:04 PM
stmacdonald99
Apr 22, 2013 12:55 PM
joelsindc
Mar 5, 2008 11:43 PM
SK8R
May 18, 2006 05:45 AM
