'04 A4 immobilizer key/remote
Old Sep 18, 2005 | 10:09 AM
tricci's Avatar
Default '04 A4 immobilizer key/remote
This was originally posted on the genl. tech board and I thought this might also be a good place to re-post.
Yes, I'm new here, but having used many forums in the past, I did what I thought was a very thorough search before posting here.
So here's my problem:
A few weeks ago, I bought an '04 A4 1.8T privately. This car came with only one "switchblade" key, the owner couldn't find the others. After reading posts here, I found a key on ebay with the same part/fcc numbers, etc. The key arrived and I had it cut by the local 'smith. Now, when I place the key in the ignition, I get a "SAFE" indication in the dash. I realize this is because the key needs to be programmed. I have tried following Audi's instructions in the owner's manual to no avail. I can only assume the remote won't program itself to the car because it's in safe mode. Or am I wrong on that count? I also realize that that will not reprogram the transponder.
I also tried several threads instructions on using the central door lock to program this thing. Not happening.
Should I go to the dealer and pay to have this done? Or is it possible I have a bad remote? How would one test the remote to see if it's D.O.A.? Any help would be greatly appreciated.
Old Sep 18, 2005 | 07:07 PM
FezA4's Avatar
Default RE: '04 A4 immobilizer key/remote
Try replacing the battery and then follow the instructions for reprogramming it... after that... rock out the Audi Dealer.
AudiGirl92
B7 Models
Aug 31, 2013 08:28 AM
MartinCieslak1
Dec 11, 2009 02:30 PM
krshrk
B8 Models
Sep 18, 2009 07:08 PM
marcink99
Jan 26, 2008 10:09 PM
tricci
Sep 19, 2005 06:05 PM
