04 audi a4 b6 misses after boosting 5psi
Old Jun 12, 2013 | 12:00 AM
teamwork123's Avatar
Default 04 audi a4 b6 misses after boosting 5psi
Have a strange sputter for roughly a week now.the car starts fine but only until it hits 5 lbs boost then it begins to miss heavily.figured it be a crank sensor.. but after replacing it the problem still exists.. read around more online and read an artical about the wires to the coil packs drying out and cracking.. inspected them.. and they were all corroded and the old rubber was brittle.. replaced all the wired re wrapped them and was certain they the problem was gone.. but it persists... If someone could provide some insite it would be greatly appreciate...thank you..
Old Jun 12, 2013 | 06:34 AM
bradtyler02's Avatar
I had a similar problem a few years ago, turned out to be a loose hose clamp causing a boost leak, but only over 5 or so PSI. It's worth doing a boost leak test to at least eliminate that.
Old Jun 12, 2013 | 11:53 AM
Thanky you brad.. I greatly appreciate the insite.
teamwork123
Jul 7, 2013 07:03 AM
teamwork123
Jun 12, 2013 11:50 AM
brokena4
Jan 24, 2012 11:29 PM
2DoubleOTDuce
Jun 19, 2010 08:01 PM
mr.cAp
Mar 24, 2008 12:32 AM
