04 audi a4 b6 misses after boosting 5psi
Old Jun 11, 2013 | 11:58 PM
teamwork123's Avatar
Default 04 audi a4 b6 misses after boosting 5psi
Have a strange sputter for roughly a week now.the car starts fine but only until it hits 5 lbs boost then it begins to miss heavily.figured it be a crank sensor.. but after replacing it the problem still exists.. read around more online and read an artical about the wires to the coil packs drying out and cracking.. inspected them.. and they were all corroded and the old rubber was brittle.. replaced all the wired re wrapped them and was certain they the problem was gone.. but it persists... If someone could provide some insite it would be greatly appreciate...thank you..
Old Jun 27, 2013 | 04:00 PM
blarshnarft's Avatar
Boost leak, do a leak down test and check for vacuum leaks.
Old Jul 7, 2013 | 07:03 AM
ImTheDevil's Avatar
You need to scan for codes. You could have ignition, fueling, or air-metering leaks. Use the information the car can give you to narrow it down instead of throwing parts at the cars. If suspect coil pack(s) or spark plug(s) first, based on typical fail points on these cars.
teamwork123
Jun 12, 2013 11:53 AM
teamwork123
Jun 12, 2013 11:50 AM
brokena4
Jan 24, 2012 11:29 PM
2DoubleOTDuce
Jun 19, 2010 08:01 PM
mr.cAp
Mar 24, 2008 12:32 AM
