'08 A4 tiptronic shifter will only downship in either direction
Old Aug 12, 2018 | 01:48 PM
plbrand's Avatar
Default '08 A4 tiptronic shifter will only downship in either direction
Here's a weird problem. My '08 A4 Avant Quattro shifts fine in "D" and "S", but when I move the shifter to the right to operate in the tiptronic mode, the transmission will only downshift. No matter if I push the shifter forward or pull it backwards, the transmission will not upshift, only downshift. The dash display seems to work properly, switching the display from "D" to the individual gears when in tiptronic mode.
I took apart the shifter to check for missing magnets, but both are in place. The connector pins for the circuit board are clean and bright. What should the individual lights on the shifter cover do when switching from D or S into Tiptronic mode?
And help will be greatly appreciated. Thank you
PLBrand
nyisles8388
Jun 23, 2012 11:59 AM
Dadan
B7 Models
Dec 6, 2011 04:30 PM
Gagt518
Apr 17, 2009 02:48 PM
ramses
Jan 26, 2009 11:31 AM
98 A4 Turbo
Apr 23, 2006 10:04 PM
