Is a 1.5 bar Greedspeed chip too much for 1.8T?
Old Sep 23, 2005 | 07:18 PM
gsxr150's Avatar
Default Is a 1.5 bar Greedspeed chip too much for 1.8T?
I found a guy who will sell me his 1.5 bar Greedspeed chip for my 02. I'm concerned that is might be overkill on the boost, being the whole car is factory otherwise. Should I stay away from somthing with this much boost? And who knows about the fuel map.
Old Sep 23, 2005 | 11:22 PM
audiboy1618's Avatar
Default RE: Is a 1.5 bar Greedspeed chip too much for 1.8T?
Greespeed uses nospeed software, is really doesnt compare to apr/giac.
Old Sep 24, 2005 | 01:57 AM
acvega's Avatar
well 1.5 bar is about 22 pounds of boost, back when the 1.8t was fairly new, sport compact car had a turbo issue and stated that because the k03 is so small, at 20 psi it is spinning at a frighteningly fast 215,000 rpm, which will kill that turbo shortly there after. I wouldn't get it, unless you need a good reason to upgrade.
Old Sep 24, 2005 | 05:14 AM
headshok2002's Avatar
I never knew greedspeed had a chip... and yeah, if they use neuspeed software, wouldn't it be crap?
Old Sep 24, 2005 | 02:49 PM
gsxr150's Avatar
acvega- That's all I needed to know. I will not be buying that chip.
Thanks guys...
Old Sep 24, 2005 | 08:19 PM
juju4uofa's Avatar
Most of the K04 chips are around 1.5bar but anything above one bar is out of the K03s efficiency (maybe 1.1bar with the K03 sport).
Old Sep 27, 2005 | 10:00 AM
OS's Avatar
OS
So what's a good chip to get if I'm looking to get more power, but at the same time retain the most reliability?
Old Sep 28, 2005 | 02:01 AM
david9999's Avatar
Welcome to the forum and familiarize yourself with the search function.
Look at APR or GIAC
Old Sep 28, 2005 | 03:30 AM
Yuikio's Avatar
ORIGINAL: acvega
well 1.5 bar is about 22 pounds of boost, back when the 1.8t was fairly new, sport compact car had a turbo issue and stated that because the k03 is so small, at 20 psi it is spinning at a frighteningly fast 215,000 rpm, which will kill that turbo shortly thereafter. I wouldn't get it, unless you need a good reason to upgrade.
God I love SCC.
2k2nyc
Dec 30, 2005 03:18 PM
bhj0887
Oct 8, 2005 08:56 PM
north5995
Sep 16, 2005 02:39 PM
krue92
Aug 31, 2005 01:26 AM
jackartist
Apr 4, 2005 02:33 PM
