10.69 @135 mph!!!! (video)
don't think this has been posted yet, but it needs to be..
this is Mike Hood's B5 A4 doing 10.69 @135 mph. he also ran two other consistand 10 sec runs
this makes him the fastest/quickest B5 audi in north america. possibly the fastest Audi in general in north americabut not sure
http://www.audizine.com/forum/showthread.php?t=159250
i know the mods list question will be asked, so for those who don't know:
ENGINE:
ATW block bored to 83.5 mm
ABA 2 liter crank
JE 8.5:1 Pistons
Pauter Rods
Ported AEB head
RaceWare heads
Schrick 252 cams
1mm over intake valves
Stock size exhaust valves
High lift, high rate valve-spring set with Titanium retainers
VR6 throttle body
Custom Intake Manifold
TURBO & EXHAUST:
Full-Race.com manifold
GT35R with .82 ar
Tial 38mm waste gate
Wastegate dump tube
3" down pipe
3" test pipe with dump outlet
3" exhaust to Magnaflow muffler
Custom Evolution Racewerks FMIC with Garrett 24x10.5x3.5 core
2.5" IC pipes
Tial 50mm BOV
HKS Filter
FUEL & TUNING:
034 Motorsport IIc stand alone with 4.5 bar map sensor
96 lbs low imp injectors
034 Motorsport fuel rail
SX adjustable fpr
-6 AN fuel feed line from tank
Bosch Motorsport 044 fuel pump from 034efi
HKS EVC4 Boost Controler
Tuned at 32psi on 110 octane
ENGINE:
ABA 2 liter crank
JE 8.5:1 Pistons
Pauter Rods
Ported AEB head
RaceWare heads
Schrick 252 cams
VR6 throttle body
TURBO & EXHAUST:
GT35R with .82 ar
Wastegate dump tube
3" down pipe
2.5" IC pipes
Tial 50mm BOV
HKS Filter
FUEL & TUNING:
SX adjustable fpr
ORIGINAL: qUaTtRoA4
gotta be the BOV!
gotta be the BOV!
If you listen, he never lets off the gas for it even to go off. Plus the 50mm Tial is the best valve you can buy and work flawlessly on mid-large turboed 1.8t's
actually he does lift on the gas. compared to what he can do, he's pretty much granny shifting. they're claiming sub 10.5 with faster shifting, cooler temps, and using his LC with slicks. perhaps he could be the first audi do hit a 1.4x 60' time
