10.69 @135 mph!!!! (video)
ORIGINAL: Belligerenceā¢
holy sh*t. does anyone want to take a stab at how much $ he's put into that drivetrain?[:-]
other than a clutch and some trans and diff mounts, his drivetrain is stock
ORIGINAL: sean1.8t
not sure if you're meaning to be sarcastic, or what type of sarcasim you're trying to acheive. but....
so my question remains, does anyone know how much money he's put into that setup?
ORIGINAL: onepoint8tee
I knew the ATW engine was good for something!
ORIGINAL: mjvss21
theres really nothing "ATW" left about it. he switched the head to an aeb
ORIGINAL: cincyTT
His engine is now 2032cc and mines going to be 2008cc
83mm pistonsvs his 83.5mm pistons.
but Cincy, i assume you are using your stock block right? what crank are you going to use? ABA? Eurospec?
but since his car is a sponsored car, money out of his pocket is probably around 15-20k in mods(remember he has had to rebuild the engine twice
this is just speculation though. i am not quoting any sources
AEG crank
Scat rods
Wiseco 83mm 9.25:1 pistons (i like compression, good for spool)
Stock ATC block same as AWD
83.5 is beyond what you should use for a street car, guessing same sources. Plus the 24cc's isnt worth the thinner cylinder walls. If you use a TDI block and crank you can go 2.1L but you cant rev as high as with the 92.8 crank. Basically, its the same as stock.
Scat rods
