10.69 @135 mph!!!! (video)
Old Sep 11, 2007 | 04:12 AM
Belligerenceā„¢'s Avatar
Default RE: 10.69 @135 mph!!!!
holy sh*t. does anyone want to take a stab at how much $ he's put into that drivetrain?[:-]
Old Sep 11, 2007 | 07:55 AM
sean1.8t's Avatar
ORIGINAL: Belligerenceā„¢
not sure if you're meaning to be sarcastic, or what type of sarcasim you're trying to acheive. but....
other than a clutch and some trans and diff mounts, his drivetrain is stock
Old Sep 11, 2007 | 03:22 PM
mjvss21's Avatar
theres really nothing "ATW" left about it. he switched the head to an aeb
ORIGINAL: onepoint8tee
I knew the ATW engine was good for something!
Old Sep 11, 2007 | 04:48 PM
ORIGINAL: sean1.8t
no sarcasm intended at all. rather, it was after 1am and I had just gotten home from work, and I meant to write "powertrain", as in engine + tranny + other driveline components.
so my question remains, does anyone know how much money he's put into that setup?
Old Sep 11, 2007 | 04:52 PM
onepoint8tee's Avatar
ORIGINAL: mjvss21
No ****! Hence, what its good for; a block aka nothing special.
Old Sep 11, 2007 | 05:13 PM
cincyTT's Avatar
I'm make believe
His engine is now 2032cc and mines going to be 2008cc
83mm pistonsvs his 83.5mm pistons.
Old Sep 11, 2007 | 05:53 PM
sean1.8t's Avatar
ORIGINAL: cincyTT
correct. some reputable sources say that you should not go over a 83.0 bore. but mike has somehow been able to do do it "relatively" reliable with his 83.5..
but Cincy, i assume you are using your stock block right? what crank are you going to use? ABA? Eurospec?
Old Sep 11, 2007 | 05:59 PM
  #18
sean1.8t's Avatar
well the number of man hours/R&D/parts is probably more than you will want to ever imagine..
but since his car is a sponsored car, money out of his pocket is probably around 15-20k in mods(remember he has had to rebuild the engine twice
this is just speculation though. i am not quoting any sources
Old Sep 11, 2007 | 06:04 PM
  #19
wazup773's Avatar
tat is sweeetttttt
  #20
cincyTT's Avatar
I'm make believe
AEG crank
Scat rods
Wiseco 83mm 9.25:1 pistons (i like compression, good for spool)
Stock ATC block same as AWD
83.5 is beyond what you should use for a street car, guessing same sources. Plus the 24cc's isnt worth the thinner cylinder walls. If you use a TDI block and crank you can go 2.1L but you cant rev as high as with the 92.8 crank. Basically, its the same as stock.
