10 Engine Fault Codes
Finally, I have some of my own fault codes to post. I was feeling left out. Anyone want to take a crack at these?
16684 - Random/Multiple Cylinder Misfire Detected
............P0300 - 35-00 - -
16687 - Cylinder 3: Misfire Detected
............P0303 - 35-00 - -
16686 - Cylinder 2: Misfire Detected
............P0302 - 35-00 - -
16685 - Cylinder 1: Misfire Detected
............P0301 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
............P0304 - 35-00 - -
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
............P1128 - 35-00 - -
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
............P1606 - 35-00 - -
18010 - Power Supply Terminal 30: Voltage too Low
............P1602 - 35-10 - - - Intermittent
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
............P1113 - 35-10 - - - Intermittent
17883 - EVAP Leak Detection Pump: No Signal
............P1475 - 35-10 - - - Intermittent
Lean condition casuing misfire. You also have EVAP system problem which can cause a lean condition. Check for vacuum leaks and the EVAP valve that sits on top of the air filter housing. Give it a gentle rap or two. It should be clicking when the engine is running if you put your ear right up to it. Check the vacuum lines coming from it especially the small grey and white check valves. The one behind the air filter can rub on the metal piece near it and get a hole.
Could also be fuel pump, fuel pressure regulator.
When was the last time you vagged? Save the codes, clear them and see what comes back.
I cleared the codes (like I should have to begin with) and have 4 that came back immediately. I replaced the check valve a couple days ago since it had a hole in it. I have an ABS module in my garage right now. That will get fixed this week.
Here's what's left over-
Have you changed your plugs since your recent turbo swapping?? I remember things werent running right for you. If you were running rich before your plugs might be messed up. There is no ICM for ATW i dont think like the older a4's have located on top of the air box. That would have been a guess for me, but im not sure where the ICM is if we have that on our engines. Im just guessing F'd up plugs. Try replacing them. The 16684 random/multiple missfire code can also indicate a bad engine speed/rpm sensor.. But since it lists specific cyl. missfires, i dont think thats it.
