10 Engine Fault Codes
yea i would bet that your getting all those codes caused from one problem. like fuel too lean.
that could cause each cylinder to indiviually misfire and many other false indications.
of course check whats cheapest first ie vacuum leaks. but if all that fails go with fuel problem.
I got a set of the Bosch F7LTCR plugs and a set of the each of NGK BKR7E and NGK BKR6E plugs. Just let me know if you any of them and I'll pass them onto you the next we see each other.
