12v question
Old Jun 14, 2006 | 12:44 PM
Theprez25's Avatar
Default RE: 12v question
yea its not worth selling it so i guess im just going to make it look real nice and just work on the suspension....
Old Jun 14, 2006 | 01:21 PM
onepoint8tee's Avatar
ORIGINAL: BadLuckAudi
it will give you a little gain but not much, it will remove the speed limiter and raise the rev limiter too
I thought the chips for 2.8's were only for the 30v?
Old Jun 14, 2006 | 09:54 PM
Theprez25's Avatar
would a bigger throttle body do anything?
Old Jun 14, 2006 | 10:41 PM
18valvesbehind's Avatar
Anything would do something... I put a big open intake on it, and then ran much bigger than stock exhaust. The 12 valve can be a great motor. It needs to breathe better. In and out. So its a start to do intake and exhaust. I didnt notice much with intake. It needs both. So when i put the Exhaust on it was quite a difference. Just run larger piping from the cats into a smaller resignator and a performance muffler. Right now there is 2 huge mufflers and small piping that are causing resistance. Or if you dont mind loud loud exhaust just run with no resignator into a performance muffler. I had run that for a while and the power ban was significantly greater. REALLY loud so i already put a resignator back in. Good Luck.
[IMG]local://upfiles/19633/7F432E7B1E5A4DA39EFED22ECEA04923.jpg[/IMG]
Old Jun 15, 2006 | 01:48 AM
wood_e's Avatar
Why bother with the intake? The audi design is GOOD. The only thing an intake does is give it a nice growl. Unless you have a heat shield an intake won't make much of a difference due to the heat of the engine.
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
