17884 EVAP leak detection pump – insufficient vacuum
Old Oct 12, 2006 | 01:29 PM
jerz's Avatar
Default 17884 EVAP leak detection pump – insufficient vacuum
I ghave CEL on AGAIN... read by VAG-COM it shows
P1476 – 002 lower limit exceeded
can it be just gas cap or a pipe from tank to fuel pump?.. thank for any idea before I bring it to dealer and they change everything...
Old Oct 13, 2006 | 01:11 AM
david9999's Avatar
Default RE: 17884 EVAP leak detection pump – insufficient vacuum
What year and model. It could be gas cap, leak in system or bad pump. If the car is under warranty take it to the dealer. If you have a Real Vagcom, PM me and I can give your the directions on how to check the Evap system pump with your vagcom. If you have the factory repair manual, it too has the directions.
Old Oct 13, 2006 | 12:13 PM
jerz's Avatar
2002 A4 3.0 Quattro.. there is nothing wrong with the car, drives the same with MIL on and off now. I reset the computer and the MIL did not come back. do you have an idea?
pete7
Aug 31, 2012 12:29 PM
pete7
Feb 21, 2009 03:23 PM
RedShoeRider
Mar 6, 2008 01:40 PM
wilder
Dec 15, 2007 08:10 PM
