18010 - Power Supply Terminal 30: Voltage too Low
Guys I keep clearing this code and it keeps coming up... Anybody knows what it might be?
Address 01: Engine
Controller: 8D0 907 557 P
Component: 1.8L R4/5VT MOTR HS D07
Coding: 06201
Shop #: WSC 06335
1 Fault Found:
P1602 - 35-00 - -
Readiness: 0110 0101
Address 01: Engine
Coding: 06201
Shop #: WSC 06335
1 Fault Found:
P1602 - 35-00 - -
Did some research, it usually a result of pulling the ecu, or disconnecting the battery and should go away shortly, if not it could be a short b/w o2 sensor wires
Ok I asked my mechanic and he says that code is not a problem at all. It shows in all the chipped cars because when you turn off your car the chip resets the ECU and the car thinks the ECU was removed and put back. So we are going to have this code no matter what.
Yea it doesnt reset the ecu everytime otherwise fuel trims would be reset and as was stated above the car would idle like crap. Its simply turns on when the ecu loses power (you took out the ecu, or disconnected the battery), it should turn off
