1997 audi A4 1.8 T transmission problem
hi guys, i got problem with PRND432 lit on and it directly shift to 3rd gear. computer check show G38 where speed sender no signal. it has been replace together with mutifunction switch but yet problem still the same. anybody can help??? pppleleeesssseeeee
Just a quick share after solve all limp problem with my audi. car turn to limp mode when just start to drive and gear on gngange at 3 gear. so many tings has been replace but yet still the same. final decision to recheck the TCU and ECU where the problem actually come from there. After complete re-program the TCU all problem gone. Thank you to the the guy who expert on re-program TCU.
Sadly even authorize agent can not fix the problem.
I rebuilt the engine of my a4 ,now that I put it back the car barely move like if the transmission have no olil pressure; I'd check the oil level and is ok, vag com say there is a fault on the multifuncional switch' .
If you put the car on drive and push the gas the car just don't go,neither in reverse,and after put the shifter back in neutral all the lights PRD234 will come on the dashboard, I'm very frustrated especialy becouse I put near $ 3000 on this long block and now the car doesn't move; if someone have any idea ,please letme know.Thanks
littlebigmon
Apr 18, 2011 01:41 AM
