1998 Audi A4 quattro severely choking
Old Jan 12, 2008 | 11:13 AM
shkrinta's Avatar
Default 1998 Audi A4 quattro severely choking
Hi everyone,
I am having a problem with a 1998 Audi A4 quattro. The history of the problem started after an attempt by my brother in law to fix the headlight switch that switchesthe regular headlights andthe bright or high headlights.Hedisconnected theswitch and he accidentaly pulled the wires out of the connector. He claims to have put them back in the right place, but the first time after the car started the problems began. The car idles just fine, but as soon as you put it in gear and you try to go, the car starts to choke andwants to die - sometimes dies too. When I say choke I mean choking like I have never seen before - shakes the entire car.The car was taken to the dealer and they looked at the switch in question and either verified it's connected right or changed it with a new one - not sure. Anyone had similar issue, or know what it could be? If the computer got messed up any idea how much a new one costs? Could it be some stupidvacuum hose that got knocked out or cracked? Please help me, I don't have the money to pay a dealer to fix the car!
Old Jan 12, 2008 | 11:34 AM
sineo's Avatar
Default RE: 1998 Audi A4 quattro severely choking
Take it to AutoZone and get it scanned for (free) then post the codes here.
Old Jan 12, 2008 | 12:24 PM
ImTheDevil's Avatar
+1 to that. Even if the check engine light isn't on, you may have a code in there that would point us in the right direction for helping you.
Old Jan 13, 2008 | 02:05 PM
shkrinta's Avatar
Well, unfortunately the scanner autozone has does not have the interpretation for Audi codes, but it has the ones for VW, so here they are
P1432 - Secondary Injection Valve Open
Explanation - Open or short circuit condition
Probable causes - Failed AIR Solenoid Valve
P1545 - Throttle Position Control Malfunction
- I am not going to describe this one because the Throttle body was replaced and the problem is still there
P0305 - The PCM has determined that a misfire has occured in cylinder #5
-this code is not specific to a brand it just says OBDII
P0112 - The PCM has determined that teh input from the intake air temperature sensor is lower than expected for the current engine operating conditions
- this code is also given not for a specific brand but again just says OBDII
Hope this helps
Thanks toall
VTEC_THIS
Nov 1, 2010 02:48 PM
shkrinta
Jan 17, 2008 12:46 PM
xternum
Nov 5, 2007 04:48 PM
jaredfromsubway
Sep 14, 2007 01:41 PM
