2.8 coolant leak... SOLVED!
Old Aug 6, 2006 | 02:01 PM
lemke's Avatar
Default 2.8 coolant leak... SOLVED!
A couple weeks ago I replaced the timing belt, tensioner, water pump, thermostat, etc., and cured a water leak down the front of the motor. I suspected the water pump. Anyway, looking good, feeling good, no more leak or so I thought.
Well, after driving in the Texas heat, the motor was still losing coolant and overheating. Upon shutting the car down, the engine would heat-soak, build pressure, and start puking coolant, this time from the rear of the motor... WTF.
I modified a differential cylinder leak down tester to pressurize the cooling system and hopefully find the leak. FOUND IT!
Even though I replaced the coolant overflow/expansion tank, it had a pinhole in it that shot a steady stream of coolant while under pressure. The previous tank had a lot of cracks and leaked as well. I replaced the tank (again) and NO MORE LEAK!
Moral of the story... if you have a phantom water leak, and if you live where it gets really hot, inspect the coolant overflow/expansion tank for any cracks or pinholes.
Hopefully this post will save someone some grief...
By the way, I purchased my parts from Autohaus, and they sent me a replacement tank and refunded the price of the defective one once I sent it back. Good people.
Old Aug 6, 2006 | 03:35 PM
techbod's Avatar
Default RE: 2.8 coolant leak... SOLVED!
ingenious 10/10
kpatz
Jul 14, 2015 11:19 PM
A4 2000
Sep 10, 2013 07:08 PM
Cioffie
May 19, 2013 10:24 PM
inventorA6
Apr 15, 2009 06:46 AM
less_of_me
May 2, 2007 03:29 AM
