Infamous coolant pipe leak solved!
Old Sep 10, 2013 | 02:26 AM
A4 2000's Avatar
Default Infamous coolant pipe leak solved!
I know many people have had or still have this problem and I wanted to share my simple, but effective solution to the problem. Since I've owned this car, I've experienced a coolant leak where the coolant flange connects to the metal coolant pipe.
I've replaced the flange twice and also tried just replacing the o-ring where the pipe connects in hopes of fixing the leak once and for all. The outcome each time was only a temporary fix or only appeared to slow down the leak.
I thought of an idea to place not one, but TWO o-rings where the pipe connects to see what would happen and VOILA! Not even one drop leaking out now. It seems that the design of how the o-ring seats itself inside the flange and pipe is not making a seal that's tight enough, thus causing the leak. Now there is a perfectly tight seal!‏
Old Sep 10, 2013 | 02:32 AM
morpheous's Avatar
awesome bro, I'm glad you fixed your issue. Thanks for sharing your fix.
I don't have a coolant leak as of yet, i have an 01 A4 B5, maybe they fixed that issue in 01, that the 00 had?
Old Sep 10, 2013 | 02:42 AM
A4 2000's Avatar
Thanks man. Not sure if it's just an issue with the 2000 model to be honest. I've just seen a bunch of posts from a few different audi/vw forums with people complaining about it on their 1.8t
Old Sep 10, 2013 | 01:09 PM
Mad Cow's Avatar
Are you using an OEM flange and oring? I had the exact same issue with an aftermarket oring that was obviously way too thin.
Old Sep 10, 2013 | 03:06 PM
Kamil`'s Avatar
You see the irony of the situation is that you are never ever ever ever supposed to use two O-rings.. at least in 95% of the applications in which they are used.
Yet you my friend have defied modern engineering.
Nobel prize coming your way.
Old Sep 10, 2013 | 04:06 PM
mtroxel's Avatar
Ditto here, except I'm talking about the 2.8. Some aftermarket O rings are square, or other shapes. I've had some leakage. The O ring really needs to be an O ring.
Old Sep 10, 2013 | 05:45 PM
Kamil`'s Avatar
Gotta love cheap Chinese knock offs.
Old Sep 10, 2013 | 07:05 PM
A4 2000's Avatar
Hmm, yes it is aftermarket from Carquest actually. Maybe their parts aren't exactly to spec.
Old Sep 10, 2013 | 07:08 PM
A4 2000's Avatar
Lol. I'm just happy it works. For how long, who knows.
kpatz
Jul 14, 2015 11:19 PM
Rn3037
Jun 28, 2014 06:30 PM
Cioffie
May 19, 2013 10:24 PM
mtroxel
Jul 28, 2012 12:07 PM
lemke
Aug 6, 2006 03:35 PM
