2.8 Q Emissions prob
Old Sep 27, 2004 | 08:39 PM
CCGIANTS's Avatar
Default 2.8 Q Emissions prob
While my car is idling, I noticed a loud "hissing" sound coming from the gas cap. You can't hear it inside the cabin, but just happened to be outside of my car while it was on, and heard it. At the same time, I have an emissions malfunction indicator light on, and my gas mileage has been poor as of late. So possibly there is a problem with the gas tank pressurizing because of pressure escaping through the cap? Happened to anybody before? Is it the cap, or a bigger problem? Thanks!
Old Sep 27, 2004 | 09:32 PM
David_K's Avatar
Default RE: 2.8 Q Emissions prob
No, you probably need a new gas cap.
Old Sep 27, 2004 | 09:36 PM
CRAZYHAWK's Avatar
Make sure the cap is tight.
Old Sep 27, 2004 | 09:40 PM
CCGIANTS's Avatar
I mean the cap is getting as tight as it's going to get, i turn it until in clicks.
Old Sep 28, 2004 | 06:00 AM
SlimChriz's Avatar
do you have a vag-com so you can check the vapor return line solenoid or you can just feel it while the car is running and hot it will be clicking
have you changed and vacuum lines under you manifold lately it one of the check valves is in backwards the vapor will not be able to get to the manifold and pressure will build in you gas tank...
the cap might just be faulty
Missingman
Aug 17, 2009 05:07 PM
limptimtim
May 24, 2008 01:10 AM
jzstuggie
Feb 4, 2008 09:32 AM
conor
Nov 15, 2006 12:41 AM
pliddy
Mar 24, 2005 12:37 AM
