2000 A4 Timing belt/kit?
Old Aug 29, 2005 | 04:58 PM
Jamaha80's Avatar
Default 2000 A4 Timing belt/kit?
Can someone explain how to install the timing belt kit with all belts and waterpump for the b5 engine without having to remove the front bumper? Or is it worth while to take the bumber off?
Also, I have a tiptronic, I have heard that the snub mount should not be replaced on it, is that true?
ALSO, sometimes changing the transmision fluid can be bad because it takes out the filings which are used as some sort of insulation between the worn gears. Is that true? I have 70k miles. Should it be done? Can I do this myself pretty easily?
Old Aug 29, 2005 | 05:07 PM
18T's Avatar
18T
Default RE: 2000 A4 Timing belt/kit?
what you need to do is replace the tensioner and water pump. not the snub mount. snub mount is an extra and is good to replace because you already got the bumper off and its easy.
and no i dont think u can install the timing belt kit without removing the bumper. i think it can be set to service position but im not sure on that.
Old Aug 29, 2005 | 05:09 PM
Jestnomen's Avatar
6th Gear
Yep the bumper must be removed. Snub mount would be an excellent idea. And no i've never heard that about the tranny fluid.
Old Aug 29, 2005 | 05:13 PM
Jamaha80's Avatar
If the engine has 70k miles on it, im going to replace the belt as well. I realize that the snub mount is an aftermarket or "extra" thing, and i have heard that by replacing it, when the car shifts, it creates vibrations, or the auto tranny isnt tough enough for it. Thanks!
Anyone with a tip tranny have a snub?
Old Aug 29, 2005 | 05:16 PM
Jestnomen's Avatar
6th Gear
Who is giving you your information? None of it has been correct thus far. Vibrations during shifting? A new snub will stop that and make shifts nice and smooth.
Old Aug 29, 2005 | 05:27 PM
Jamaha80's Avatar
I read it in a forum, maybe this one. If you are an expert I'll take your advice. I'd just like to hear it from someone who has experienced the application.
Old Aug 29, 2005 | 05:33 PM
Jestnomen's Avatar
6th Gear
I have experienced it...
2.8 Auto:
Did the timing belt change myself. After 80k miles the old snub mount was all worn out and brittle/hard. Shifts were butter smooth after a new snub.
Old Aug 29, 2005 | 08:07 PM
sandman's Avatar
if you dont have much automotive experience dont do it your self!!
Old Aug 30, 2005 | 01:13 AM
JettaRedII's Avatar
Here's a really good step-by-step: http://www.audiworld.com/tech/eng35.shtml
rbrianpeters
Dec 29, 2013 12:27 AM
wagner1968
Jan 11, 2010 12:47 AM
Mike2000tt
Aug 14, 2009 11:49 PM
mtnbiker13
Mar 8, 2009 06:32 PM
transporter55
Oct 4, 2007 07:56 PM
