2001 Audi A4 1.8T
Old Jun 14, 2004 | 02:31 PM
dudley doright's Avatar
Default 2001 Audi A4 1.8T
I just bought this car with 80K miles and thinking of changing the oil into synthetic.
Can someone tell me if this is a good idea or not? Which brand and grade should I get? Your help will be appreciated.
Old Jun 14, 2004 | 09:28 PM
CRAZYHAWK's Avatar
Default RE: 2001 Audi A4 1.8T
On previous cars I used Mobil 1 which is compatable with mineral oil. I now use mineral oil 10-30W SL. Audi changed my oil 6 times at 10,000 mi. intervals. Their mineral oil always remained smooth. I now change it every 8,000 mi.
Old Jun 15, 2004 | 12:35 AM
ImolaS4's Avatar
There are good synthetic blends best suited for high mileage cars.
Old Jun 15, 2004 | 10:55 AM
I just put in a 5w-30 Castrol syntech. Is that good or bad move in my part?
Old Jun 15, 2004 | 12:31 PM
ImolaS4's Avatar
ORIGINAL: dudley doright
It's OK, but not the best choice. Run with it for the next 3000 - 5000 miles and then consider something else.
There is only one thing I can say about Castrol Syntec that may give you reason to think twice.
Castrol Syntec is not really a synthetic oil. Here's why:
Mineral based oils contain different hydrocarbons, some of which tend to crystallize into a waxy material at low temperatures. Pour point depressants are chemicals, which reduce the size of wax crystal formation in mineral based oils. Castrol uses a hydroisomerized process to chemically change these wax-creating molecules. This is good except that they call it synthetic; it's technically not.
Old Jun 17, 2004 | 03:43 PM
What would you recommend to use then? I used Amsoil back in 1986 for my Dodge Colt Turbo when synthetic was $15 a litre and my car had a problem in the winter time. I have never used synthetic ever since until now. So, what is the brand that most people here used?
Old Jun 17, 2004 | 03:53 PM
Doose's Avatar
Mobil 1 or Royal Purple are both very good synthetics. Purple is pretty expensive and can be hard to find depending on where you are located. Mobil 1 is less expensive and easier to find and as long as you are changing it on a regular basis I don't think you'll see a difference between the two. As for Amsoil, I've never used it myself, but I've read pretty good reviews on it. I've run Purple in my 2000 A4 Avant 1.8t since 15,000 miles. Currently I am running Mobil 1, because it is much easier to get.
Old Jun 17, 2004 | 04:02 PM
What viscousity do you recommend if I use the Mobil 1? Should I stick to 5W30 or 15W50?
Wtftylor
Nov 1, 2012 01:01 PM
nukauto
Feb 2, 2008 11:02 PM
Jorgen
Aug 7, 2006 11:29 AM
Bit646
May 11, 2006 05:24 AM
