I have a 2004 A4 1.8 AWD which misfires at startup for about 30 seconds. I took it to the Inskip Audi in Rhode Island and they charged me $600 to clean the injectors and replace the plugs but after 3 days I had the same problem so I refuse to take it back for more service and more money.
Here is what I know.... it never misfires when driving. I get a DTC code of P0301 or P0302 ( check engine flashes while its misfiring) when I start the car. After 30 seconds or so engine runs smooth and check engine stops flashing.
If the car sits for long periods like more than a week its fine, if I start it often its fine, Often is about every few hours. The misfire mostly happens if it sits overnight.
I also changed the all the coil packs which did nothing. Cost was $120.
One thought I had was that the #1 and #2 injector was leaking into the cylinder when parked overnight and when it sits for long periods the fuel evaporates and this is why I don’t get the misfire if its sits for long periods. Also when it sits for short periods of time I don’t have the problem is because not enough fuel leaked from the injectors.
This is only a theory and I hate to buy 2 injectors for $100 each to find out this made no sense.
Anybody have any ideas on other possible things to check???
