2004 S4 Misfire and Low Compression
Old Jun 30, 2014 | 05:20 PM
audiLarsK's Avatar
Default 2004 S4 Misfire and Low Compression
The compression is as follows:
1) 60 psi
2) 90 psi
3) 100 psi
4) 75 psi
5) 20 psi
6) 0 psi
7) 30 psi
8) 60 psi
After putting a few squirts of oil into the cylinders to check for ring leaks, the compression was:
1) 122 psi
2) 105 psi
3) 100 psi
4) 120 psi
5) 30 psi
6) 0 psi
7) 95 psi
8) 118 psi
I also am throwing codes P0300, P0346, P0305, P0306
Almost no power
I replaced the coils and plugs all the way around
Also, idle is rough and there is a loud whacking sound when it is first started, subsides after a few times, and goes away on subsequent starts.
Any ideas other than faulty rings?
Thanks in advance!
Old Jun 30, 2014 | 05:46 PM
audiLarsK's Avatar
Also replaced both cam position sensors
Old Jul 1, 2014 | 07:06 AM
bradtyler02's Avatar
It's very possible the cylinder walls are scored pretty bad, which means you either need a new engine, or a complete bottom end rebuild from JHMotorsports ($10K+)
audiLarsK
Jun 30, 2014 05:20 PM
BER995
Jun 3, 2013 05:29 PM
simonA6
May 1, 2012 02:17 PM
lbv001
Jun 20, 2010 03:09 PM
jasonkp1978
Oct 6, 2009 08:00 PM
