3 Beeps from right rear on startup
Old Nov 8, 2007 | 08:59 AM
trauh's Avatar
Default 3 Beeps from right rear on startup
Driving a 2002 A4 quattro. When the car has not been driven for a day or two, it will issue 3 or 4 beeps (more like chirps maybe) from the right rear.No maintenance messages. And it only does it when its been sitting for a day or more. Car is garaged. battery is new (just a month old). Any thoughts?
Old Nov 8, 2007 | 09:02 AM
hiwords's Avatar
Default RE: 3 Beeps from right rear on startup
not sure which side the fuel pump is on the b6 but it could be that just priming the engine for a start up. it should be fine unless u notice that ur car loses power during higher rpms
Old Nov 8, 2007 | 01:10 PM
trauh's Avatar
While doing some research I saw a note suggesting that this type of beeping might be caused by a weak alarm siren battery. That was in a UK post; does anyone know if there is a separate alarm siren battery in the US?
Old Nov 8, 2007 | 02:44 PM
Flip's Avatar
Yes the alarm uses a seperate power source so that when the car isn't on your battery isn't drained.
Old Nov 30, 2007 | 08:43 AM
trauh's Avatar
Here's an update for anyone else with this issue. It definitely is the alarm siren beeping, which is apparently a warning that the dedicated alarm battery is low on power. It is a hassle to replace the battery (the whole unit is one piece).
I realized that the car hadn't been locked (e.g., alarm on) in 3 or 4 months, so I decided to see ifmaybe the alarm battery only charges when the car is locked. After leaving the car locked for a week, we haven't had the 3 beeps since. I can't be positive that this was the fix, but I'm thinking that was it.
Old Nov 30, 2007 | 01:58 PM
kchao2000's Avatar
That's a good info to know. So I won't be panic if I hear the beep sound next time 'cuz I am also having a B6.
zoharerlich
Dec 27, 2013 07:05 AM
Pablo_Ottawa
Apr 29, 2007 07:53 PM
Deb38
Feb 11, 2007 07:53 PM
Pete_the_Puma
Apr 3, 2006 11:26 AM
apg96
Aug 6, 2005 02:11 PM
