40,000 mi check
Old Mar 3, 2005 | 11:33 PM
K69camaroz28@aol.com's Avatar
Default 40,000 mi check
What is checked during this???? What maintaniance is done normally? Lastly how much will touching up a scrach cost??
Old Mar 3, 2005 | 11:45 PM
Doose's Avatar
Default RE: 40,000 mi check
THis is for a 2000 straight from the Audi USA website. As for the scratch, can't be that much, I think I paid about $300 to have two and dent pulled out of mine. Hope this helps.
* Engine Oil - Change the oil.
* Engine Oil Filter - Replace the oil filter.
* Cooling System - Check the coolant level. Add coolant if necessary.
* Dust and Pollen Filter: Replace.
* Air Cleaner: Replace Filter.
* Engine, On-board Diagnostic - Check diagnostic trouble code memory with VAG 1551/5051. Purge if necessary.
* Doors - Lubricate door hinge mechanism.
* Battery - Check electrolyte level. Add if necessary.
* Windshield Wiper and Washer - Check fluid level. Add fluid if necessary.
* Automatic Shift Lock (ASL) - Check operation, including park/neutral position switch (where applicable).
* Manual Transmission - Check gearshift mechanism and clutch for proper interlock operation.
* Tires and Spare Wheel - Check for wear and damage. Check the pressure.
* Service Reminder Indicator Display - Reset the display.
* Brake System - Check for damage and leaks. Check thickness of pads and brake fluid level.
* Drive Shafts - Check the boots.
* Front Axle - Check dust seals on ball joints and tie rod ends. Check the tie rods.
* Automatic Transmission - Check for leaks.
* Manual Transmission - Check for leaks.
* Transmission Final Drive(s) - Check oil level. Add oil if necessary.
* Dust and Pollen Filter - Replace filter.
* Headlights - Inspect headlights. Adjust if necessary.
* Sliding Roof - Clean guide rails and lubricate with grease spray.
* Road Test - Check kickdown, braking, steering, heating, ventilation, air conditioning, power accessories, and electrical system.
* After Road Test - Engine: Check for leaks, Power Steering: Check the fluid level, Exhaust system: Check for damage/leaks.
Old Mar 3, 2005 | 11:54 PM
Thanks a ton dude!!!
Old Mar 4, 2005 | 12:04 AM
PandaXpress's Avatar
they just look at stuff its a waste of money
Old Mar 4, 2005 | 04:30 PM
Still under warrenty so i dont care as long as i get a loner
Old Mar 4, 2005 | 04:44 PM
clconversion's Avatar
what they replace the oil, oil filter, pollen filter, air fliter and top up fluids if they are low how is this a waste of money ?
joeynach
Aug 27, 2011 06:57 PM
parlayin
Feb 10, 2010 12:33 PM
mys4.org
Oct 16, 2008 03:19 PM
