5th gear whine
Old Dec 13, 2007 | 03:45 PM
A4speed's Avatar
Default 5th gear whine
I thought at first it might be a rear wheel bearing, but I don't think it's that at all. When I am in 5th gear and and am in full acceleration, there is a weird sound. I don't know how to explain it exactly, but its kind of like you can hear your tires rotating as your driving, the sound is kind of like: wa wah wah.
Also, when I am going 50mph or faster, when I put my foot off the gas, I can hear the exhaust a lot more now then I use to?
Anyone know what this could be?
Old Dec 13, 2007 | 03:54 PM
Darknight101's Avatar
Default RE: 5th gear whine
No idea but why complain about hearing the exhaust more? I have the same sound but only during crusing at 50+ under full there is nothing but meat.
When did the sound start? Has it always been there?
Old Dec 13, 2007 | 04:01 PM
A4speed's Avatar
Started a little while after I had my 18" rims put on (about a month ago). I went to the tire shop and he said it sounds like something to do with the transmission since it's only doing it in 5th gear.
Old Dec 13, 2007 | 04:30 PM
techbod's Avatar
interesting that it started when you changed the wheels ( are the tyres rotational and on the right way? ) tranny noise would come from the front rather than the rear, bearing noise gets louder the faster you drive and the exhaust could be a bad muffler so the noise would be more noticeable
Old Dec 13, 2007 | 04:32 PM
A4speed's Avatar
do you think it could be an alignment issue then?
they are all-season tires and i hope they were put on the right way
Old Dec 13, 2007 | 04:37 PM
techbod's Avatar
very possible also did they need to fit spigot rings to center the wheels as without them the wheels would sort of wobble a bit
http://images.google.co.uk/images?hl...ings&gbv=2
edit: also check if the wheels have the correct offset
Old Dec 13, 2007 | 04:44 PM
A4speed's Avatar
I have no clue if they installed those rings or not, i just dropped off my car and picked it up. I'll call them and check.
ORIGINAL: techbod
how do i check that?
Old Dec 13, 2007 | 04:52 PM
techbod's Avatar
Old Dec 14, 2007 | 12:35 AM
A4speed's Avatar
if it is only doing it in 5th gear and not the others could it be an issue with the tranny?
Old Dec 14, 2007 | 07:57 PM
cincyTT's Avatar
I'm make believe
check for any uneven wear on the tires and the muffler insulation is probably burning up a little causing it to become louder.
EuroSlut
Jun 6, 2011 05:42 PM
Matt Sterne
Oct 17, 2006 10:19 PM
